I know it will be little bit hard but my car is already customized -
And its not problem for me to change some items under the mask
I saw whole theme, I know there is problem with exhaust mainfolds.
Where is problem with gearbox holder ? With Fan I think no problem ,I can put the cooler forth.
Firewall ? I think only right side - its too tight there - I can use hammer there - im just joking.
I know its a little bit work but can You write directly what I need to do with those few things ?
It will be great if You can make few more pictures of Your engine holders - on the engine of course ...
I know the engine must be in perfect position otherwise there will be problem with connecting the gearbox and shaft.
And on the original holders engine lie on the steering gear.
Now I know that I need to make more space for cover of the valves - those two aluminium black/silver ones that are on the top of engine - right side is too tight , left is ok.But lower steering gear block engine - and it needs to be higher ...
