Проблем при инсталация на WIS/ASRA
5 мнения по тази тема
#1 jores
jores
  • 4 Мнения:
Публикувано 09 март 2024 - 19:43
Инсталирам успешно EWA и добавям валиден StartKey, но при инсталацията на WIS Database през EWA Admin Tool поличавам грешка:
Checking of the locally installed EWA version contained on the medium has failed. Please make sure the original medium is inserted.
Installation of the WIS database has failed.
Прикачен файл  EWAadmin error.jpg   111,25K   7 Брой сваляния
Опитах с две различни версии, но получавам все една и съща грешка:
Mercedes Benz WIS-ASRA 2022.11
Mercedes Benz WIS ASRA 2020.10 Full
Някой знае ли къде може да е проблема?
Благодаря.
#2 valdemar
valdemar
  • 118 Мнения:
    S203 M271 C180K
Публикувано 09 март 2024 - 19:47
Мисля че не ти отрива iso-то. Сложи го във виртуален драйв.
Sent from my RMX2155 using Tapatalk
#3 jores
jores
  • 4 Мнения:
Публикувано 09 март 2024 - 19:51
Сложено е, но логовете казват:
Sat, 9 Mar 2024 08:50:40.133 main INFO com.hp.tis.admintool.interaction.AdminToolGUIManager WIS net installation Step 1: Check WIS StartKey completed successfully. Sat, 9 Mar 2024 08:50:40.133 main INFO com.hp.tis.admintool.interaction.AdminToolGUIManager Start WIS Installation Step 2. Sat, 9 Mar 2024 08:50:40.133 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Valid WIS installation media found in "D:\" Sat, 9 Mar 2024 08:50:40.148 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Starting WIS full installation with full medium. Sat, 9 Mar 2024 08:50:40.179 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Start splitting in subrom files Sat, 9 Mar 2024 08:50:40.179 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00000.000 File size null Sat, 9 Mar 2024 08:50:40.179 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00000.000 splitted into 2 sub romfiles Sat, 9 Mar 2024 08:50:40.179 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00001.000 File size null Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00001.000 splitted into 1 sub romfiles Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00002.000 File size null Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00002.000 splitted into 4 sub romfiles Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00003.000 File size null Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00003.000 splitted into 5 sub romfiles Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00004.000 File size null Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00004.000 splitted into 1 sub romfiles Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00005.000 File size null Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00005.000 splitted into 1 sub romfiles Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00006.000 File size null Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00006.000 splitted into 1 sub romfiles Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00007.000 File size null Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00007.000 splitted into 1 sub romfiles Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00008.000 File size null Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Rom file: rfile00008.000 splitted into 1 sub romfiles Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Finished splitting in subrom files Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Looking for hook file 'D:\wis\datahook\wisnethook.ini' Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.WISInstallationHandler Could not find or access wisnethook.ini file on primary WIS installation media. Using default values instead... Sat, 9 Mar 2024 08:50:40.195 main INFO com.hp.tis.admintool.functional.InstallationHandler Local EWA version: , Media EWA version:
Явно го намира, но твърди, че файловете за празни, което не е вярно.
#4 valdemar
valdemar
  • 118 Мнения:
    S203 M271 C180K
Публикувано 09 март 2024 - 20:12
Виж какво има в тоя wisnethook.ini там трябва да има пътеката в която очаква да е медията
#5 jores
jores
  • 4 Мнения:
Публикувано 10 март 2024 - 08:39
Няма изобщо такъв файл.
#6 Georgi_Kr
Georgi_Kr
  • 2 Мнения:
  • Град:Костенец
    MB W124 200TE 1994г.
Публикувано 14 юли 2025 - 12:29
Благодаря.
 Здравей , при мен се получи същия проблем.
Ако си с по-нов windows (примерно 10 или 11) трябва ISO файловете да го отвориш като натиснеш: десен бутон - отвори с - windows explorer.
След което отвори EWA като администратор
След като са се отворили 2-та файла , пусни да се ъпдейтва WIS-а
Този пост е редактиран от Georgi_Kr: 14 юли 2025 - 12:30
