Здравейте колеги, светна ми чек енджина с тази грешка някакви съвети
Грешка P0010Колата е C200 Kompressor w203, 163HP, 2003 година
Started by canbroc, 11 Oct 2015 - 15:27:18
4 replies to this topic
Posted 11 October 2015 - 15:27
Posted 15 October 2015 - 10:02
Питай чичко GOOGLE
Posted 15 October 2015 - 18:49
Ето какво излиза след кратко търсене в гугъл
С две думи грешка в системата за контрол на разпределителния вал.P0010 code refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control
module). That consists of an oil control valve (OCV), also called a solenoid valve and other components. Basically the check engine light and associated P0010 trouble code means that the voltage in the circuit has fallen below a set limit for a specific amount of time (varies by make/model/engine).
Symptoms
Symptoms may include:
* Check Engine Light illuminated (Malfunction Indicator Lamp)
* Rough running
* other symptoms may also be present
Causes
A code P0010 may mean that one or more of the following has happened:
* Faulty oil control valve (OCV)
* Open or short in the VVT/VCT circuit
* Open or short in the OCV / solenoid valve
* Damaged computer (PCM)
Possible Solutions
Some recommended troubleshooting and repair steps are:
* Carefully inspect the Bank 1 VVT/VCT system circuit wiring and connectors, repair as required
* With a warm engine, test the operation of the OCV, replace/repair as needed
Edited by frxbg, 15 October 2015 - 18:50 .
Posted 15 October 2015 - 20:12
Така наречения Ванос
Posted 01 November 2015 - 00:28
Благодаря за отговорите
