Снимки на МБ190
Започната от phantasm, 12 май 2006 - 00:34:52
20 мнения по тази тема
Публикувано 12 май 2006 - 00:34
Предлагам в тази тема да пускаме снимки само на този автомобил!
190 2.5 D estate
2.3-16v estate
190 coupe
190 2.5 D estate
2.3-16v estate
190 coupe
Публикувано 12 май 2006 - 00:35
Публикувано 12 май 2006 - 00:38
Публикувано 12 май 2006 - 00:42
2.5 16v
Публикувано 12 май 2006 - 00:45
Ето снимки на колегите от UK Форума:
Rammbs
Blonderabbit
Bazza
Thomas
Cossie Connoisseur
Nickaliath
Rammbs
Blonderabbit
Bazza
Thomas
Cossie Connoisseur
Nickaliath
Публикувано 12 май 2006 - 00:52
Engine: 4 Cylinder fuel injected engine. 2498cc, light alloy cylinder head with twin overhead cams and 16 valves. Mechanical/electronic fuel injection with cut off. Microprocessor controlled ignition. Approx 205bhp @ 6200rpm and 175 ft/lb torque @ 4500rpm. factory 4-branch tubular manifold, Remus back box, K&N performance air filter. 0-60mph approx 6.9 seconds, top speed approx 150mph.
Transmission: Getrag 5-speed close ratio manual gear box with "dog-leg" first gear and direct 5th gear. 3.27 rear diff with ASD (self locking diff). Short shifter kit.
Suspension/Steering: Shock absorber strut independent front with wishbones and anti dive, negative offset steering, multi link independent rear suspension with 5 links per wheel, anti dive and anti squat control. Electronically controlled auto locking differential (ASD) W124 27.5mm front anti roll bar, EVO2 18mm rear anti roll bar with W124 metal end-links. Adjustable Koni Sports shocks front and rear, 40mm Koni lowering springs, 2 bump spring pads front and rear - SLS removed. PAS, collapsible column, 3.5 turns lock to lock.
Brakes/Wheels/Tyres: Dual circuit power assisted braking system. Wilwood Dynalite aluminium 4-pot calipers with 310mm vented, drilled disks on front. Fixed caliper disk brakes at rear, vacuum brake booster, wear sensors, ABS, EBC Redstuff ceramic brake pads, Goodridge stainless steel brake hoses. 17x8J, ET35, 5x112 OZ Opera's, 215/40/17 tyres, AMG valve caps, blue laurel centre caps.
Body: Clear Front & Side Repeaters. Black painted headlamp wiper arms, main wiper arm and grill insert. De badged rear, LHD drivers mirror. Replaced chrome grill and badge assembly for a smoothed body colored grill. Stock 16v body kit. Original Carlsson rear wing - smoothed boot lid.
Interior: Full black leather seats and door panels, 2 seater rear seat with center armrest, electric memory drivers seat, 4 electric windows, electric mirrors, electric slide/tilt sunroof, air con, heated seats, power steering. Luisi flat bottom steering wheel. Racing short shift gear change.
Публикувано 12 май 2006 - 01:01
big al merc
Публикувано 12 май 2006 - 01:02
joburger's 2.3 Sportline AMG
Публикувано 12 май 2006 - 01:03
Публикувано 12 май 2006 - 09:20
MattMoore
Публикувано 12 май 2006 - 09:22
nav
Публикувано 12 май 2006 - 09:28
Dave's 1.8
Публикувано 12 май 2006 - 09:37
sunstealth
redfar
redfar
Публикувано 12 май 2006 - 09:40
W201 vs W202 (Enegergie's W201)
dave_irl
dave_irl
